#386199
Do you mean Mirror X & Y? If so, these do not flip the image, they rather cause every other tile to be flipped (poor-man's seamless tiling), which means you'll see no effect when using Repeat values of 1.0 (because this math applies only within the context of UV space). If you want to flip the image for every tile, leave Mirror X & Y off, and use negative Repeat values.
