#386136
Could someone confirm that displacement type Loop/Catmull-Clark isn't working in MayaPlugin 3.1.9 ?
What is interesting, same object (simple cube) is working with Studio, but following error shows up in console when I launch render from Maya.
[Flat type is working as it should.]
[Extension SubdivisionModifier] Modifying mesh..
ERROR: - [Extension SubdivisionModifier] An edge connecting two vertices was specified more than once. It's likely that an incident face was flipped
ERROR: - [Extension SubdivisionModifier] This object cannot be subdivided.
tested with Windows 7 x64 SP1, Maya 2015 SP5, Maxwell Render 3.1.1.0 + MPlugin 3.1.9
#386194
The difference between Maya and Studio is that when you import the obj into Studio, it gets triangulated. The Maya plug-in exports quads when the object contains them, so the geometry which is subdivided is not the same in the two cases.
It looks like the engine has a bug in the subdivision code when quads are present. I've forwarded the problem to the engine guys.
