By Fernando Tella
#385566
Without knowing the in and outs of extrasampling, it works by selecting well defined regions on screen. It speeds up the process by rendering only part of the image instead of the whole, but lights usually flood the whole image and don't have a defined edge. I guess you want a completely different thing: instead of selecting a region you would like to stop the calculations on some lights and continue with the rest, right?
Maybe that would somehow distort the light solution?
I can see some situations where that feature would be useful, like lamps that don't contribute much to the illumination of the image apart from the look of the lamp itself.
Maybe that would not be necessary if the "importance" of lights were automatically equalized before starting the render so all the lights cleaned at the same time (which is something that can be done by hand but is a bit tedious).
By Fernando Tella
#385574
I would say current method is more like "continue render in a region" based on a mask. You can obtain masks from objects, materials, custom alphas,... but not from lights. I think it's a different concept.
I mean, I find it useful, don't get me wrong, but I guess it's not just adapting the thing to lights. Hopefully it's easy to do.
Last edited by Fernando Tella on Tue Feb 24, 2015 10:24 pm, edited 1 time in total.
By seghier
#385575
i don't mean masks :)
the light applied to all the scenes ; i don't mean apply light to some objects ( we can use block emitter in this case )
if we use two lights ; one light quickly calculated and give clean image but the second need more time
if we have option to stop calculation of any light in the scene
sl 18 for the first and sl 23 for the second : it's extra sampling
By eric nixon
#385578
Fernando, that's a good point. That's something I've forgotten. Also a vague recollection something changed in this regard, but pretty sure thats the way it works now.... The idea is to make the small lights extra bright then dim them with multilight, right?, but then how much brighter? Trial and error would indeed be tedious and kind of counterproductive with a deadline looming.
... No worries there, it wouldn't change the appearance of anything.
By rdtBCN
#386142
I jump in the chat, as I would also find useful a feature where you could select which light sources would need extra sampling and stop the others when they are clean when using multilight. We actually have an interior scene where all passes of the lights inside the room are clean at 18 SL, but sun and environment require extra sampling.
Hoping this could be implemented in future versions!
Roberto
By dariolanza
#386147
Hello rdtBCN,
Extra Sampling per light is not as time saving as it first may sound.
First, it would involve a different way to store data on the MXI, that would make our well-packed MXI file to be at least double weight.
Second, as fortunately in Maxwell the number of light sources doesn't impact the render times as dramatically as in other render engines, sampling 2 lights on the same scene will not be much faster than sampling 5. If your render is still noisy because of a couple of times, I would suggest you to add a couple of Sampling Levels more to the whole scene. Being other lights on this new render wouldn't make it significantly slower, and the gain in visual coherency, algorithm cleanness and file size and Ram needs do will be noticeable.
If you don't have more time to render, other solution is that if there is certain light noisier than others, you can use the unique capabilities of Multilight to separate your light buffers in Photoshop or After Effects, and apply any noise reduction strategy only on certain selective lights, while maintaining the sharp details from the rest.
In addition to that, if the noise from that "noisiy" emitter is affecting certain located area or object, you could easily use the Extra Sampling to clean it up.
And finally and more important, if in your interior what is causing that noise is definitely the indirect lighting from the environment and sun, I would strongly suggest you to follow these photographer advises to speed up this kind of situations: http://support.nextlimit.com/display/tu ... or+renders
Let me know if this helped to clarify this question.
Greetings
Dario Lanza
By rdtBCN
#386276
Hi Dario,
thanks for the reply and insight on the issue. It was just an idea after seeing that the MXI extracts an image for each light source when importing it in After Effects or Photoshop. Then of course, we users just ask and request without the knowledge of the software build :)
In the end we rendered a couple of samples more and the image looks really good, hardly grain, just enough to make it look well balanced/realistic.
Greetz!
