By boda
#385222
I tested the new TP network method. The network work fine (all clients are logged at server) but the scene is not sent
I attached in this post the screenshot to show when tp network stops working
Thanks
Bye
Carlo
#385223
boda wrote:Hi,
Thanks
Bye
Carlo
Perhaps the params reading daemon could not open the MXS. This can be because of it not finding the pymaxwell library from the %MAXWELL3_ROOT% (very unlikely since you are using a bundle with maxwell itself), or because the mxs makes he params service to crash (if it could not be opened because of a corrupted-outdated mxs a red-backgrounded error message would appear, but it would not get stuck)
Does it happen only with that mxs or with any other? In the former case, could you upload somewhere the file where I can reproduce it?
Do the manager still run after you get to this? is there something on the manager log window? does it just get stuck? Perhaps restarting the manager with a higer (info/debug) log level can yield more information on this case.
Thank you for testing this,
