Not a silly question at all, as in the past it did happen to me to close the manager when the monitor said it was done but the manager did not actually finish to send the mxi file yet. Oops.
In this particular case i checked in the morning to be sure the monitor, the render nodes and the manager were done: since all the status were quiet I assumed it was done and I close all down but the final mxi file were missing. Gone. Even the previous mxi preview which I run hours earlier was nowhere to be found (of course maxwell delete *everything* after it closes no matter what you specify in the prefs). Not the first time I got into this: it is entirely possible in the past I did close one of 3 moving parts before checking so it may be my fault few times, but the bottom line is that I should follow this rule: never, *ever* close any of the apps till you check the actual file is actually done and written on disk, but if there is any smell of funky issues at *all* copy all the files from the temp directory before closing anything. In fact it is a safe procedure once in a while to backup files while it's still rendering, especially for the very long, expensive ones.
To explain what I consider "funky" it is any issue where the monitor or manager or render node is not doing what it has been directed to do, like reporting jobs as finished while it may be still rendering or merging, refusing to pick up jobs after being paused, not respecting the que order, render nodes not picking up any more jobs after finishing a render, unable to reset, unable to stop, etc.
I get problems like this randomly and they may be caused by network issues, but honestly after working with maxwell on 2 studios plus mine (which went trough at least 2 generations of routers, servers and render nodes) the only common denominator over all these issues seems to be the network rendering itself.
To be honest is really, really difficult to report these problems: I tried really hard in the past but it was time consuming and in the end next limit support could not understand were the problems where based on my reports, which is understandable without being on site.
I gave up on reporting years ago because of that but the problems are still there: sometimes I get lucky, sometimes I may do mistakes, but sometimes the network rendering catch me with the pants down. I' m still walking funny after last one.
My solutions are to follow the rule above or use deadline: deadline or running renders manually (which is almost the same thing) never failed me.
So I'm looking forward to the next generation, which sounds very, very promising.
Gianca
Mihai wrote:Well, I apologize if this sounds like a silly question but you're sure it's not the Manager you closed? Because the Monitor only reports what the Manager tells it, and the Manager runs the show. Network rendering works without any Monitor, you would use it only to add jobs, then you can close it and reopen it when you like, it will receive its data from the Manager again.
But in any case, this new system is not fully ready for the 3.1 release and we will release a testing version of it soon, probably after the holidays. We still need to transfer over some of the features already present in the current system.
