#384212
I cannot make extra sampling work. Everything seems to keep rendering full frame.
I launched a render (from 3dsmax) specifying paths for mxi and mxs and with a custom alpha active for a box in the scene. I let render get to SL8 and stop it; then activate Extra Sampling, select custom alpha (which rendered fine), set SL to 20, and resume render. It keeps rendering the full frame. The same thing happens with a bitmap loaded.
I'm using Maxwell 3.0.99.3 and plugin version 3.1.2
Any one else?
#384241
Ok, got it!
The render goes on full frame until global SL has been reached and then continues with the extra-sampling region, right?
After posting the capture I tried with global SL4 and extra-sampling 20 and it worked fine.
Success finally!
I have to say though that while this behavior is correct and quite predictable specially for animations I thought that by just activating extra-sampling the render would continue on that region from current SL.
Usually with interior stills I just set a very long time and high SL and stop it when I feel it's ok. In this case I would have to stop, set a lower global SL, activate extra-sampling, resume and wait for the full frame to reach the new global. Maybe an option to "from now on continue only on extra-sampling region" would be useful.
