By AlexP
#383816
Hi Marton,
Are there any chances that mxs proxies can be displayed as point cloud or wireframe objects? It's really hard to place irregular trees as box ;)
Best regs
By Marton Day8
#383819
Hi Alex,
Do you use the V3.0.x version of the plugin? If yes, it is already possible. How do you create proxy object?
There is a new way to do it by open the AC Object Library > Embedded Library > Maxwell Library and there you can see Maxwell Referenced MXS.
Place one object give the path (with the Mini Library editor is should be easy), and there you have.
Márton
By Rafal SLEK
#383822
...and this works really fine :-) Mini Library Editor is great place to change parameters on-line - uncheck "Show only the Placeholder" option.
By Rafal SLEK
#383824
Marton Day8 wrote:Thanks for the visual support Rafal:)!
