#383488
Hi im a bit of a stuck noob I have used the wizard with the "Textured" preset in Maya to connect texture map of mine and an alpha map which is rendering but I need to add a bit of shine to the surface like the shine to get on Cellulose Acetate "Film Negatives" how do I going about this?
Thank You........
#383610
as I'm not sure what kind of effect you want, I can only suggest this:
create another material with the shine you want and merge both,
or just add a layer (with or without coating) on top of the wizard's layers ?
