By egmehl
#382537
I'm considering adding Modo to my pipeline and I'm wondering if it's possible to export a .mxs scene via python? I'm coming from Max where I can basically just call one function with the output file as a parameter that triggers the built-in plugin export code and there it goes.
Is there a similar way of doing this in Modo + python?
By Marton Day8
#382541
Hello,
You should invoke a modo command in python
The command is:
scene.saveAs "C:\#TEMP\mySceneName.mxs" "Maxwell MXS" false
Change C:\#TEMP\mySceneName.mxs to your output file name.
Márton
