#382334
SolidWorks frequently crashes when adding/removing/editing/updating materials in the plugin. I haven't been able to figure out a pattern, so it seems somewhat random. I use linked materials and mostly edit materials in the Maxwell Editor, but also use the SWx Plugin editor.
I can paste a crash report if it helps.
- Ian
#382355
It depends on the nature of the crash report; are you referring to the plugin's Exception dialog report, or something else? That said, given your other post, it may be due to version issues between components (plugin, Maxwell).
