By lebulb
#381813
I did a lot of testing, but it does not work. (Maxwell 2.7.2 and Zbrush 4R6 P2)
The settings are the same for Maxwell V2 and V3?
I read this V3 topic and this V2 topic and i use the JDHill settings,
but the result is weird : (3D Rel.Tan. 0-black / Scale 1)
When I disable vd Tangent I have the same kind of results (y deformation inverted).
Any idea?
lebulb
By Polyxo
#381827
You will need Maxwell V3 for correct Vector Displacement from Zbrush.
It comes not only with optimized settings but also with quad-based displacement
which works greatly better for VD than V2's triangle based solution. In V3 one even
has presets for several digital sculpting apps.
By lebulb
#381831
Thanks a lot Polyxo.
V3 its not for me now :? but it will :)
I wonder though how JDHill made ​​its export in this case.
Is to test at the moment so it is not essential.
Thanks
