By ababak
#381785
Hello!
I've been successfully using network rendering with most of my jobs but today one job is stuck on sending dependencies.
Here's a file list collected with Pack'n'Go (just to test):
Here's the file list from render node's temp folder:
That's how Network monitor looks like:
The log from render node:
20 minutes later network monitor showed an error:
It doesn't matter how many render nodes I use or how big files are.
Can you suggest something?
Thank you!
By umdrehung
#389211
Same trouble here.
Funny thing: with Maxwell 3.1. it worked just fine. Now with 3.2 it's stuck on sending dependencies.
Did you manage to get it work again?
By ababak
#389212
No, I've never got a response on this matter. If I remember correctly, I used a local render to finish this job. Since then I was lucky enough to not see this problem again.
