- Fri Jun 27, 2014 5:27 am
#381564
There seems to be an issue with applying materials using the "Load Material from Web" option. My log always shows that the material cannot be found. Inside of Maxwell Render, the error message indicates that program is looking for the material in another location other than where it was downloaded; it seems to be pointing to the path where the material was saved on the original creators computer.
How do you override that path?
Thanks in advance for your help.
Revit 2015
Maxwell Plug-in version 3.0.13
ERROR: - File "\\HORIZON-LP88WIQ\Maxwell 2\materials database\mxm files\Jason Made\SheerCurtain\textures\weave_normals.png" has not been found. Render cannot continue.
Revit 2015
- By Andreas Hopf
