By seghier
#381106
I read about birefringence in my old book of physic (double refraction) ; i tried yesterday to create calcite material
"The measure of birefringence (δ) [delta] is the difference between the indices of refraction of the two rays. δ = ne − no"
left : test of calcite material , right : glass material
For calcite :
calcite CaCO3
no=1.658
ne=1.486
δ= −0.172
The calcite material created with two bsdf's
The first with nd = no
The second with nd = ne
That give birefringence effect but i am not sure if maxwell give the right effect
Because there exist two types of birefringence (double refraction) : uniaxial negative and uniaxial positive
In this case we need to apply the law : δ = ne − no to get the right effect.
The question : if maxwell can give the right effect ; how?
Or maxwell need birefringence in material editor ?
Realistic rendering of birefringency in uniaxial crystals :
http://www.cg.tuwien.ac.at/research/pub ... -paper.pdf
Birefringency-Based Realtime rendering of translucent material :
http://www.ijfcc.org/papers/150-K00012.pdf
http://physics.info/refraction/
By itsallgoode9
#381107
ohhhhh, this is nice. I've been mulling over this effect in my head lately for my bottle renders but I never knew exactly how to approach it. when looking at real whiskey bottles i've noticed they all have this sort of "blurry" or "greasy" look to them, very similar to that calcite material.
just to clarify, that image isn't something you rendered in maxwell, it is something rendered in that paper?
even though it's not physically correct way to do it, could you emulate this using two bsdf in a material with one of the bdsf having a flat normal map to create the illusion of those offset refractions? I remember a thread a few years ago where somebody created a glass material that looked like there was a layer of glass inside of a layer of glass (or something like that) by using a normal map to hap one layer look offset.
By seghier
#381109
many materials have the same effect if you see in the last link
with normal map i didn't tried that .
the image rendered in maxwell ; i tried to increase the effect by increasing the nd of the second bsdf ( nd=2.5) but that not real.
calcite :
bsdf : nd=1.658
bsdf : nd=1.486
δ < 0
ice :
bsdf : nd=1.309
bsdf : nd=1.313
δ > 0
Seghier, I think what you render is pretty correct because, when we assume crystals as isotropoic entities, it should be as simple as mixing 2 BSDF with different Nd as you've already done. The paper is talking about view dependant anisotropic crystals which is not possible to render with current Maxwell.
Actually, you are right about it. Because, a real birefringent material is view dependant and your example calcite should keep its main refraction intact while its second refraction moving when you rotate the object on the paper. This can't be simulated with the current material system.
By numerobis
#381146
seghier wrote:requested for realism :D
i hope see this feature before v4
speaking about realism i really would prefer to get working caustics first... after almost 10 years :roll:
