#386978
Yes, I see this, though to trigger an update, it should be enough to activate the locked view (meaning, rather than lock/unlock, just click in the view to which the camera is locked), correct?
By kami
#387308
considering the locked fire view, I got one similar wish.
If you change the camera in a different viewport (by moving the camera point) it does not affect the fire camera. It would be great, if that could be possible because I'm using the top view a lot to optimize the camera position and I need to have it to locked mode, otherwise fire will switch to the top view.
#387314
Yes, this is what AlexP was referring to in his two previous posts. As noted, FIRE should be updated if you just click in the viewport it is locked to -- it works that way for you, correct?
Maxwell for Rhino on Max missing Toolbar
Hello, For some reason, the Mac version of Rhino[…]
Let's talk about Maxwell 5.2
Price for sure matter a loot. Speed is the core i[…]
hardware question :)
1) give us a budget limit 2) write down what hard[…]
Materials translucent with V5.1
Well, the problems can be in the chair, the monito[…]
