By doc
#380041
hi,
i want to render an exterior from two different views and want to render the file on rebusfarm.
i made an animation for the camera. frame 0 is cameraposition1 and frame 1 ist the same camera in position 2. did it in this way, because the stageobject didnt work with maxwell.
if i render the file from cinema in maxwell, everything works fine, but by exporting the file to the renderfarm, the farm is starting the job and stops it at once.
thx in advance
#380042
I don't really understand the situation, so could you please send me (jeremy at nextlimit dotcom, or dropbox) a Cinema file, and also two MXS files you exported from it (one for each camera frame), which would show this behavior?
By doc
#380043
thanks for fast answer and help. problem is just solved.
upload directly from cinema to renderfarm isnt possibel for only a few frames. thats the reason why the farm doesnt start the renderjob. it has only two frames.
i must sart the written mxs by special tool from rebus and select different cameras there. everything is perfect.
thank you
