By Igor Posavec
#379510
Hello,
Max2014, Maxwell 3.0.0.3., Bug
Each time you open MMx and add fractal procedural (noise etc) and close mmx (save material setting), max does not accept it. When you open it, the definition is lost, and it is gray again. I have so far not found a way to render procedurals in max.
thanks
best regards
By Mihnea Balta
#379514
Procedurals aren't supported in any of the plug-ins currently. The only way to render them in Max is to use a referenced material, which you edit only with MXED. Don't import the MXM into an embedded material, because Max will ignore the procedurals.
