By pi
#379326
Hi all
I have some incomplet export (render) in many situations with 3.0.8 plugin MaxwellSDK 3.0.0.4.50 and Revit 2014.
None of the revit links (rvt files) are exported.
And Some Beams, Parts of curtain walls and Walls with parts don't render in models without any links.
I have just this laconic message from the plugin
"Void GetElementGeometryData()0"
Can you fix this issue please.
By pi
#379332
Thanks a lot for the quick fix, it's ok now.
Another one, sorry 8)
Pack'n Go crach
Unhandled exception .......
Starting a transaction from an external application running outside of API context is not allowed.
Thanks again for your efforts
By kyleB
#380536
Hello,
Im having a similar problem with my revit plugin, when I export the MXS file everything in Revit looks correct but then when I open the file in Maxwell Studio or Render it is missing parts and pieces of the building and in some cases there are pieces that are floating off of the building.
Any help that you can give would be much appreciated
