- Wed Mar 05, 2014 12:48 pm
#378501
Hello again,
it appears i have 2 different problems, but one of them seems to be just an display bug
Case one (display bug?):
In short: all frames will be exported, but the window disappears after half of them.
I want to export an animation, timeline is set to 70 frames (start 1, end 70)
export progress window appears, telling me the range is 1-70.
Blue Statu-Bar and Frame Status aren't syncron. as you can see in the image.
This ends in an window which disappears, after the bar reaches the end. but modo is still exporting the other 35 frames.
Case two (render bug)
In short:After export, maxwell starts rendering normal - after reaching the desired SL and start of the 2nd frame it's telling me something is missing. in the sample scene, i created it's the environment, in my current project it's a missing uv map.
strange things are:
1. frame one works fine
2. rendering a single frame (no animation) works fine, too
3.maxwell v2 renders the entire animation without problems.
sample scene >https://www.dropbox.com/s/mof8zrxxrt2fe ... n_test.lxo
screen of the error >
MacOs latest, maxwellv3 LE, modo 701 SP4
strange things are:
- By Andreas Hopf
