By astanelle
#378473
Hej there,
i've a little problem here, i'm not able to get the extensions running trough the modo plugin.
That's what i need:
That's what i'm able to do:
https://www.dropbox.com/s/72807nev2uylf ... ll_sea.jpg
In short:
How can i use the maxwell sea extension inside modo. running 701SP4, MacOS latest, maxwell v3 LE
I'm missing the Maxwell Extension Tab .... ?!
Best regards :)
By photomg1
#378480
you need to add a maxwell extension object first into your shader tree….
in modo
under items > Add item (from the pull down top right) >select Maxwell>Maxwell extension object
with the maxwell extension object selected in the shader tree open the plugin . Under Maxwell object you will now have Maxwell extension with a pull down menu( set to none). Click that and change to maxwell sea .
It shall now appear :D
#378510
About visibility:
Is it still the sea extension? (Visibility possibilities are dependent on the actual extension.)
Additional info:
In case your license is not full license, visibility in viewport is limited.
Márton
#378515
hmm, that's a pity. especially because your customer support told me "there are no restrictions on the functionality of the plugins" .... :(
I would't mind, but that was a feature i was interested in. :(
#378589
Hej Marton,
as you mentioned the limited display of the maxwell sea geometry in the LE Edition, i noticed a huge performance drop ( resulting in off time between changing more than one parameter ) if working in big scale. i guess the plugin still perform the visualization-process in the background, because it's running smooth again if i turn of the visibility of the maxwell see object.
i can live with the workaround for now, just wanted to know if there is a possibility to kill that background visualization process for the LE edition, because it's just time consuming and don't add anything for me ^^
best regards
As a side note: can we have the same Order for the for the maxwellsea parameters like it's displayed in Studio ? actually it's
Modo Plugin:
- Wind
-- Wind Speed
-- Wind Direction
-- Wind Alignment
-- Min Wave Length
-- Weight Against Wind
Maxwell Studio
- Wind
-- Wind Speed
-- Wind Direction
-- Wind Alignment
-- Min Wave Length
Used Studio to preview the sea, ( because the performance drop in modo) and than copied the setting to modo, didn't noticed the different order in the first place, so i got a different result. ... :P
