By zoet
#378156
I assume Maxwell is failing to translate the alfa channel from the ArchiCad materials on the trees here? Is there a way to force it, or do you guys know of any better trees to use inside archicad (I get none of the ones that can be downloaded directly in ArchiCad to work)?
(In the image the outer portions of the walls are disappearing as well due to some mxm materials not being rendered, but I have posted that issue in a separate thread.)
It looks more like a smooth normal problem. Like i[…]
I had some very strong highlights in some material[…]
Daydreamer
Thanks everyone! I didn't want to use volumetrics […]
opening V5 files in v6
just installed latest version for Rhino V6 when I[…]
