By Tyrone Marshall
#39072
This started initially as a test subject with the cinemaxwell plugin but the quality was pleasing enough that I decided to add it to the gallery.
Although the SSS quality is very good, the tubes actually have different SSS settings. The absorbance and SSS ratio currently does not seem to be as sensitive as the results from other tests that have been made with SSS. I will conduct one more test with this scene to see if color lightness has an effect on this as the color is maybe darker than it should be for SSS. At least that is my theory and I am sticking to it!
Here are the statistics:
MAXWELL 1_2_1_beta ( Engine core: rs1c )
[ Physically and Unbiased Based Rendering ]
## Scene Information ##
6 meshes ( 3662 triangles )
target sampling level: 25
sampling level reached: 19
Tubes absorbance and SSS settings in order of image:
[1]-------------------[2]----------------[3]
Abs: 0.001----------Abs: 0.5----------Abs: 1
SSS:0.001----------SSS:0.5----------SSS: 1
Tubes are 300.44 inches tall with outside diameter of 16 inches and inside diameter of 4 inches.
Emitter Light Emission Bands are 25 watts with preset 'C'
Diffuse Black Bands have a high absorbance ratio to prevent light bleeding of light from emitters.
Camera settings:
S/S: 1 ISO: 500 fStop: 8
Unit scale: 0.0254
No post processing except to add copyright information.
Thanks to ImageShack for Free Image Hosting
By Kabe
#39235
...it's subtle, but to me it looks like the bleeding above the black bars is thinner for the left configuration.
Kabe
