- Thu Feb 06, 2014 12:27 am
#377565
I'm using maxwell Render 3.0.0 and I'm having an issue with the Maxwell Sea extension. When we apply a Sea extension on a Rhino plane the result is not as we would expect. The mesh showing on the rendered image is 100x times bigger than the original surface. And it's impossible to scale it down. When we scale the surface the resulting mesh is not scaling accordingly. I don't have the same issue when I add a Sea extension in Maxwell Studio. Has anyone managed to apply Maxwell Sea correctly on a Rhino surface ??
Thank you
Karim
Thank you
Karim
- By Matteo Villa
