-  Wed Jan 29, 2014 9:47 pm
					 #377329
							Has anyone else had trouble with grass where it does not use the material you specify in the grass window and it instead comes out grey?
This was a problem I often had with Version 2 and the only way I could find to fix it was create a new material and re-assign the material in the grass menu. (re-doing what I had already done) and then it would work. Now I just did a rendering which I did a test render on my desktop (with 3.0.0.1) and it was green as expected.. so I did a pack and go to final render on another computer... and grey grass. What am I doing wrong?
 - By Forum Moderator
