By Mihnea Balta
#376956
Version 3.0.4
  • fixed: emitters were exported incorrectly, sometimes causing the render to hang during voxelization
By Mihnea Balta
#381195
Version 3.0.5
  • re-added support for the legacy material, but its UI only contains a "convert to layered" button
  • fixed: crash when trying to perform image adjustments and a texture did not have any image layers
  • fixed: crash when removing a Maxwell shader from a surface which had both a normal and a backface material
By Mihnea Balta
#388591
Version 3.2.0
  • added support for the nested priority material parameter
  • exposed the "grow toward world Y" parameter on the grass object
  • added support for Maxwell 3.2.0
