By voltaire_ira
#38828
hello,
How do i load an mxi as an emmiter in max? i tried using an emmiter material and clicked on mxi map but it cant load images created from the mxcl viewer with an xxx.mxi format.
how do you set-up your scene and render settings? do you need to turn on physical sky?
any help will be appreciated. i've tried sifting through the forums but couldn't find the right procedure.
