By Mihnea Balta
#383532
Version 3.0.6
  • re-added support for the legacy material, but its UI only contains a "convert to layered" button
  • fixed: crash when trying to perform image adjustments and a texture did not have any image layers
  • fixed: crash when removing a Maxwell shader from a surface which had both a normal and a backface material
  • fixed: emitters were exported incorrectly, sometimes causing the render to hang during voxelization
