By gbarrett333
#373850
Hello, I am receiving a mesh-export error message when attempting to render a scene from Rhino. Does anybody know how I can fix this?
Thank you.
#373851
Please paste a copy of the error text here, so I can tell you what might be happening.
By gbarrett333
#373852
Choose Option <RenderScene> ( RenderScene RenderSelectedObjects ToFire=No UseViewNameAsOutputName=No ForceNewMeshes=Yes ): R
Maxwell: Rendering camera 'Annex Interior'.
Maxwell: -- BEGIN Path Status Report --
Maxwell: Total number of Materials: 18
Maxwell: No invalid paths found
Maxwell: -- END Path Status Report --
Maxwell: Exporting new data, press Esc to cancel.
Maxwell: Exporting meshes...
Maxwell: Mesh transfer 10.00% completed (301 of 3011)
Maxwell: Mesh transfer 19.99% completed (602 of 3011)
Maxwell: Mesh transfer 29.99% completed (903 of 3011)
Maxwell: Mesh transfer 39.99% completed (1204 of 3011)
Maxwell: Mesh transfer 49.98% completed (1505 of 3011)
Maxwell: Mesh transfer 59.98% completed (1806 of 3011)
Maxwell: Mesh transfer 69.98% completed (2107 of 3011)
Maxwell: Mesh transfer 79.97% completed (2408 of 3011)
Maxwell: Mesh transfer 89.97% completed (2709 of 3011)
Maxwell: Mesh transfer 99.97% completed (3010 of 3011)
Maxwell: Mesh transfer 100.00% completed (3011 of 3011)
Maxwell: Warning => Invalid X-Axis base value (caller=object.setBaseAndPivot)
Maxwell: Error => Invalid X-Axis base value (caller=object.setBaseAndPivot)
Maxwell: Total export time: 00:00:06.8413913.
Maxwell: Warning => Errors detected in scene creation phase. MXS will not be created. (caller=writeMXS)
Maxwell: Error => Errors detected in scene creation phase. MXS will not be created. (caller=writeMXS)
Maxwell: Warning => The Scene was not successfully written due to an internal Maxwell error.
The specified MXS was: D:\1 PARSONS\1 2013 Fall Semester\Studio III\Ice House Renderings\Maxwell Render outputs\Annex Interior Noon January 25th.mxs (caller=EndWriteMxs)
Maxwell: Warning => The .mxs was not written due to mesh-export errors. (caller=Render)
#373853
I've not seen that before, and will not be able to tell you much without seeing the 3DM file, so if you could please upload it to dropbox or similar, then post a download link here, or via email (jeremy at nextlimit dotcom), I'll try to find the reason.
#373857
Thanks -- I'm not yet sure about the underlying reason, but it is being caused by a group of spotlights in the scene, which are oriented perfectly upwards. If you rotate them even a thousandth of a degree, the error will no longer occur.
