By wimver
#372989
how can I remove clipping in the preview window? if I zoom out, some parts of objects in the far distance dissapear partly. z-clip planes are not used, this happens with the perspective view, not with a camera.
Thanks,
Wim
Uploaded with ImageShack.us
By wimver
#373017
Thanks Mihai, that seems to do the trick, and I found out it starts happening when selecting a tiny element, pressing C to center that element and then zooming out again, gives the z-clip effect (objects partly dissapear parallel to the film plane)
@seghier: there was no camera yet, just the perspective view, I import geometry from MoI as .obj files
wim
Do you have a huge scene (in size) compared to that little object? It might happen in such cases the OGL viewport gets confused and starts clipping. When you press C it moves the camera target (even if it's a perspective view it still has a "target") to the center of that object, so if the rest of the scene is very large and you zoom out a lot...
