Everything related to Studio.
By cslawes
#372957
After working in a scene for a period of time dragging objects around stops working this can some times be fixed by importing the scene into a new studio file is there a quicker way to fix this problem or avoid it happening
By cslawes
#373132
I have checked the selection mode and switched between them to check. Closing studio and re-opening the scene doesn't work it only corrects the problem by closing studio, starting studio and inserting the broken scene into the new blank scene its very odd, any selected objects are always movable by changing the position values but this can be slow moving to get objects positioned correctly
That sounds very strange, could you do a small video capture of the screen? So you still see the gizmos when you try to move the object? If the gizmos are too small or too big, you can resize them by pressing Alt+ plus or minus on the numeric keypad.
