By QuakeMarine1
#370916
win R14 x64 plug2.7.22
creat landscape obj
creat MXS obj (setup output name and folder)
save and try to run that file in batch
"C:\cinema\CINEMA 4D 64 Bit.exe" "c:\test.c4d" -nogui -rendermxs
last message i see is "exporting" and nothing happen
without batch the scene render fine
that tooks me 4 hour to find ! thanx
#370920
Thanks, I am able to reproduce this, but cannot tell you what causes it -- execution enters a Cinema function and apparently never returns. When I first implemented the ability to export MXS with -nogui, I found some undocumented gotchas that had to be worked around (things you can normally do can cause hangs or crashes with -nogui), so my best guess would be that there is something like that happening inside the landscape object -- at least, I have observed no similar behavior with any other objects.
I'll try to boil this down to a simple case and send it along to the maxon developers.
