- Wed Sep 11, 2013 4:15 pm
#370794
I want to clarify an issue with emitters...I have created a single group for an emitter which is made up of an open cone shaped light fixture with a mirrored inner skin (which a fellow Maxwell user recommended i do) and a small polygon emitter inside which has approx 14 faces. I have applied a material to the emitter with a wattage of 100 and efficacy of 50. I have then copied the light into a number of positions to use it as light for pendants and giving general light around a room.
Will each light have a wattage of 100 or will it share the wattage between all the lights if it is use the same emitter made from one material in sketchup? I can never remember when it shares wattage power and when it doesn't!
When i am just using the emitters to light a scene I find that there seems to be more noise than when using just the sun or both emitters and sun. Is there any reason for this? perhaps i have set the emitter up wrong? These are quick renders on drft engine up to around 8 SL but they give the idea.... the EV is 10 in both
compared to this with the sun
Thanks,
jonathan
Thanks,
jonathan
- By Lucas Macabéo
