#370642
Dear all
I've been following the work of David Brinnen, and in one of his renders there's a material which I'd like to reproduce, but I'm struggling. I think it's some kind of SSS or rough glass. I've asked David but no response yet. I'm hoping that some of the more experienced material experts on here can point me in the right direction.
Before I show you this material, please don't moan that it's not rendered in Maxwell. The material in question is the orange cube on the right (not the ribbon):
Image copyright David Brinnen 2013
Any help would be appreciated.
Thanks
James
By bograt
#370645
Hi James, I'm pretty sure that's not sss. Looks more like a translucent material with semi-diffuse refraction which may be difficult to recreate in Maxwell, It looks almost hollow so thin sss might be worth a try.
#370696
Hello James,
I've recreated a material following the render you submitted as a reference.
I made it using SSS. I think it is pretty close to the original reference. It will be easy to tweak.
Just tweak the Attenuation Distance and SSS_Coef according to your object thickness.
And of course, tweak the Transmittance color to match your needs.
Being that dense translucent material, it can be an expensive render.
Attached I'm sending you the MXM material itself and a sample test render.
I hope it is close to your needs.
Enjoy!
Dario Lanza
#370709
Thanks Dario! And thanks for your e-mail, I hope the reply got back to you OK.
dariolanza wrote:Hello James,
Enjoy!
Dario Lanza
Caustic render channels
Try selecting refractions in render channel and in[…]
First Maxwell render for some time!
Hi, A just for fun project to model and render th[…]
Hi everyone, has anybody found a way to use and e[…]
Modeling from spline
Thanks - I came across the same thing myself recen[…]
