#370250
Yes, it turns out SketchUp is destroying the license validator when it unzips the RBZ. So, we have put up new installer-based packages for download, available both via the customer portal, and on the regular download page.
Alternatively, you could also just rename the plugin .rbz to .zip, unzip it, and run LicenseValidator.app directly from there (inside, you'll find it at maxwell/lic), since the regular Apple unzipper is not causing the same problem.
