How much would you spend?
$995 thats £546
27
51%
$400 thats £220
18
34%
$200 thats £110
8
15%
By alan2here
#37973
This program seams fantastic
As I understand
_You can make your own 3D shapes
_It renders them photo realistically
_(The times when it doesn't seams to be down to human error.)
_I also see that is can generate shapes like this
_http://www.maxwellrender.com/forum/viewtopic.php?t=2862
_(The top image, this could be great for sand in a desert)
_Deal with liquid dynamics and rigid body physics to make animations.
_It optimises the render to make it simpler for you so you can
_concentrate on your complex geometry and surface properties.
However it cost
$ 995 (£546)
As revolutionery as maxwell is does enyone else find this a bit steep?
Edit: Ignore that, read my next post further down.
By bonsak
#37992
Maxwell can not generate shapes its only a render engine.
Maxwell is different from other render engines because it
uses simulated radio waves to simulate reality.
Check out the prices for other engines: Mental Ray, Renderman, Brazil
and then you can come back and tell every body here if you still think Maxwell is expensive.
Ok Maxwell is not finished yet but eventually it will be a production render.
Regards
Bonsak
By philipbruton
#38037
This piece of software is fantastic but you don't seem to have a grasp of what it actually is.
It's def worth the money imho !
By mmhnemo
#38041
Has anybody seen my watch?........
Is this your watch? I saw a guy take it away. Wait ill draw a picture...
P.S.: This poll ought to get pulled ;)
By alan2here
#38071
Here
Ok I suck and got it wrong
Maxwell is just a render engine.
I will take your words that it is good value for money
It just seemed expensive.
I agree that it is the best render avalable.
http://www.maxwellrender.com/forum/viewtopic.php?t=4083
http://www.maxwellrender.com/forum/viewtopic.php?t=4042
If I were to buy maxwell it would cost more than all other software I've ever bought added togeter.
By tlass
#38168
the best renderer available ... :D
By alan2here
#38444
Maxer wrote:Alan2here are you planning on buying Maxwell?
No, as I don't own any software for creating objects (like Maya or Xsi)
I thought it did more (see the top post).
btw. I use a pc (windows xp)
