- Tue Jul 02, 2013 7:42 pm
#369024
what i want do is, read mxs, check for certain objects by name, append matching to new mxs and save.. simple, but always python crashes after i call getObjectNames(). If i am getting object by name, everything is fine, but in this case, i am not going to know the name before real processing..
any ideas? am i doing something wrong? thanks a lot.
environment is: Mac OS X 10.7.5, Python 3.2, pymaxwell 2.7.20..
code:
code:
Code: Select all
output:
#!/Library/Frameworks/Python.framework/Versions/3.2/bin/python3
# -*- coding: utf-8 -*-
from pymaxwell import *
def main():
print(Cmaxwell.getEngineVersion())
Mx = Cmaxwell(mwcallback)
Mx.readMXS("test_object23.mxs")
nms = Mx.getObjectNames()
for n in nms:
o = Mx.getObject(n)
main()Code: Select all
crash log excerpt (for the lucky ones who know how to read it):
$ ./bug.py
2.7.20.0
Python(21295,0x7fff77880960) malloc: *** error for object 0x101b04d40: pointer being freed was not allocated
*** set a breakpoint in malloc_error_break to debug
Abort trap: 6Code: Select all
Process: Python [21028]
Path: /Library/Frameworks/Python.framework/Versions/3.2/Resources/Python.app/Contents/MacOS/Python
Identifier: Python
Version: ??? (???)
Code Type: X86-64 (Native)
Parent Process: bash [20999]
Date/Time: 2013-07-02 18:54:11.605 +0200
OS Version: Mac OS X 10.7.5 (11G63)
Report Version: 9
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
objc[21028]: garbage collection is OFF
*** error for object 0x101124ac0: pointer being freed was not allocated
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff91ab0ce2 __pthread_kill + 10
1 libsystem_c.dylib 0x00007fff8b53d7d2 pthread_kill + 95
2 libsystem_c.dylib 0x00007fff8b52ea7a abort + 143
3 libsystem_c.dylib 0x00007fff8b58d84c free + 389
4 _pymaxwell.so 0x00000001013247ab CobjectRenderBase::~CobjectRenderBase() + 363
5 _pymaxwell.so 0x00000001013258e0 CobjectRender::Cpointer::free() + 48
6 _pymaxwell.so 0x0000000101318b13 Cscene::freeObjects() + 99
7 _pymaxwell.so 0x0000000101316966 Cscene::free() + 342
8 _pymaxwell.so 0x0000000101316c1d Cscene::~Cscene() + 13
9 _pymaxwell.so 0x00000001012ebf12 Cmaxwell::~Cmaxwell() + 34
10 _pymaxwell.so 0x00000001012ebec9 Cmaxwell::~Cmaxwell() + 9
11 _pymaxwell.so 0x000000010120eff3 _wrap_delete_Cmaxwell + 301
12 org.python.python 0x000000010000c828 PyObject_Call + 104
13 org.python.python 0x000000010000e0b6 PyObject_CallFunctionObjArgs + 406
14 _pymaxwell.so 0x0000000101207a26 SwigPyObject_dealloc + 117
15 org.python.python 0x000000010004c3fb dict_dealloc + 155
16 org.python.python 0x00000001000617a5 subtype_dealloc + 949
17 org.python.python 0x000000010003858d frame_dealloc + 109
18 org.python.python 0x00000001000b4345 PyEval_EvalFrameEx + 29989
19 org.python.python 0x00000001000b4ffa PyEval_EvalCodeEx + 1770
20 org.python.python 0x00000001000b530f PyEval_EvalCode + 63
21 org.python.python 0x00000001000dc6ab PyRun_FileExFlags + 187
22 org.python.python 0x00000001000dc979 PyRun_SimpleFileExFlags + 521
23 org.python.python 0x00000001000f1e65 Py_Main + 3237
24 org.python.python 0x0000000100000e0b 0x100000000 + 3595
25 org.python.python 0x0000000100000c94 0x100000000 + 3220
- By Matteo Villa
