By eirose
#368888
I got the error message while doing batch renderings.
[27/June/2013 13:11:25] ERROR: TCP message from manager is not a XML message!
[27/June/2013 13:11:25] ERROR: Data type:2
I export mxs files for animation and use network monitor to add into batch works(Render by another computer in local network).
However, the message pop-out after it render few mxs files.
Does anyone know what's that mean?? How to fix it?
By bitmover
#373587
I'm having the same issue, I have 480 frames I need to render and adding all of them at the same time crashes the monitor. Nothing seems to work after that leading to a restart of manager and all the nodes. What am I doing wrong?
EDIT: Figured it out, Should have pick animation instead of batch job, duh.
