#366963
I have installed the Maxwell Render plugin on my Windows 7 PC running the latest version of SketchUp v8.0.16846 and Silverlight 5. The plugin seems to run the install process correctly and without error and the plugin appears in SketchUp. The plugin used to work. THE PROBLEM: The plugin no longer works on this machine (it used to and I have reinstalled both SKP and Maxwell plugin). When you select "fire" or the "scene manager" it launches but the dialog boxes are just inactive and gray... nothing happens. Need help ASAP! I deleted all remnants of a previous Maxwell plugin per the readme file text. How do I fix this?
