By mitchrichie
#365855
My scene was rendering fine and then I tried to add a particle emitter in maya and get the following error when rendering in Maxwell:
[18/March/2013 15:52:39] Loading Extension Geometry..
[18/March/2013 15:52:40] [Extension MaxwellParticles] Initializing Extension Object
[18/March/2013 15:52:40] [Extension MaxwellParticles] No embedded particle data and no filename supplied, exiting operator...
WARNING: - Error loading Extension Geometry. The render process cannot continue.
ERROR: - Data preprocess failed. Render cannot continue
[18/March/2013 15:52:40] Ending render process..
ERROR: - Render Failed
I deleted the emitter but it looks like the particle shader is still there and I'm wondering if that's what is causing the error. I go to delete the the shader and Maya says: // Error: Non-deletable node 'particleCloud1' cannot be deleted.
Any ideas?
