By Ernesto
#365598
Hello,
I have a sequence of 24 images, of an animated material.
I know how to create a Maxwell material, using the first map in the sequence, but I wonde how to create an animated material to be rendered in a Maxwell animation.
Thanks in advance.
Ernesto
By Mihnea Balta
#365604
Animated textures work the same in Maxwell as they do in any other Maya renderer. Enable "Use Image Sequence" on the file node and make sure your texture frames are called something.FRAME.ext. The frame part must be padded to 4 digits.
