- Wed Feb 13, 2013 5:33 pm
#364947
I've got a fairly large (710,391 faces) SketchUp file that, mostly, came from a Revit model that hangs at Voxelization when using FIRE. I've not been able to isolate it to any specific geometry as all layers, individually, render out with FIRE just fine.
I understood why this was happening under the standalone plugin interface (32 bit application limiting memory usage) but I thought with the full RS this wouldn't be an issue since, as I understood it, the RS was taking over the rendering and, since it's 64 bit, lack of memory shouldn't be a problem.
Have I simply reached a point where FIRE and/or SketchUp can't handle the file? Or might there be something wrong with the file itself?
When I export the scene to Maxwell Render it renders as expected.
Thoughts?
Thoughts?
