- Tue Feb 05, 2013 6:43 pm
#364768
I have a rendering I am working on that I wanted to render at a larger resolution... I was basically doubling 1920x1080 so it was 3840x2160 for a large board. (which I realize is actually quadrupling pixels)
It renders fine at 1920, but at 3800 Maxwell render crashes while it is processing / voxelization etc.. I get out of memory errors. I got this list of error files below... but when I go to the folder the files are not there?
C:\Users\render1\AppData\Local\Temp\WERDE1E.tmp.WERInternalMetadata.xml
C:\Users\render1\AppData\Local\Temp\WERFB6F.tmp.appcompat.txt
C:\Users\render1\AppData\Local\Temp\WERFD34.tmp.mdmp
Anyway I tried increasing the page file to 1.5 times my ram... (Ram is 16gb) but that did not help either. Any suggestions? Am I asking too much relative to the rendering size on a complex model?
I am using a lot of large proxies for trees. There are also a lot of emitters.
The Maxwell scene file from sketchup is 275MB. No grass. No materials with Displacement.
The machine is... Intel R Xeon R CPU E5-2690 0 2.90GHz 32cores 16 GB Maxwell2.7.20.0 Win64
Thanks for any suggestions..
Derek
Derek
