By limbus
#364731
is it possible to change the color of meshes when using Viewport 2.0?
When using smooth shade, maxwell materials and Viewport 2.0, all meshes are shaded in green. Other materials shade correctly. I could not find a way to change the color.
Florian
By Mihnea Balta
#364925
The Maxwell material supports viewport 2.0, so it should show the correct colors and textures. Are you using the latest plug-in? What video card and Maya version are you using?
By limbus
#364936
Mihnea Balta wrote:The Maxwell material supports viewport 2.0, so it should show the correct colors and textures. Are you using the latest plug-in? What video card and Maya version are you using?
The textures show correctly but if I use smooth shaded view, all objects are green.
- Maya 2013 with all SPs
- Quadro K5000 (its the same with a Quadro 4000)
- Plugin version 2.7.8
Cheers, Florian
By gotoxy av-media
#364968
How can you see textures in Viewport 2.0 if you are not in smooth shaded mode?
I am using maya2013, MX-plugin 2.7.11 and Quadro5000, having no trouble with green objects.
Viewport 2.0 has some problems to refresh the textures, if you are editing materials...clicking on recalc thumbnailPreview in the mxm, helps refreshing the viewport!
munch
