By vpii
#364658
Can anybody confirm that instancing in 11.5 now is broken in lightwave. I installed 11.5 today and reinstalled Maxwell plugin and instance does not work now for Maxwell. So far everything else seems fine.
By DarkLane
#364726
I´m able to use instancing through the particle emitter just fine and can use the maxwell plug-in to render it all out. I´m using 2,7,20 and LW 11.5
By vpii
#364754
Could you try to use lightwave native instance and see if it works also? It was working in 11 but does not seem now in 11.5
By DarkLane
#364782
No problem here with native instances or with particle instances. Successfully rendered out a group of instances.
I did have some trouble with triangle geometry rendering out blank earlier but i think that´s a long standing "issue"
