#364613
Hi There!
What does that mean? Thats from Maya 2013 with plugin 2.7.11 on XP64.
Thanks in advance for your help.
Roshan
Number of arguments on call to maxwellCopySceneAssets does not match number of parameters in procedure definition.
Start of trace: (command window: line 1).
maxwellCopySceneAssets (command window: line 1).
performFileAction (command window: line 0).
projectViewer (command window: line 0).
fileOptionsAction (command window: line 1).
#364619
It's a bug in the plug-in. It means that pack'n'go doesn't work from the file->export menu, i.e. if you enable it in the export options, the MXS file is written correctly, but the depedencies (textures, IES files etc.) aren't copied. We'll fix it for the next build, but in the mean time if you want to perform an export with pack'n'go, please use the shelf button (5th from the right) and enable "Export mxs file" in the dialog that pops up.
