- Thu Dec 20, 2012 5:10 pm
#363792
seem like PF export to mxs depends on polycount of parent object somehow.
If I create PFsource with 200 particles and use teapot as instanced geometry - working fine, i see 200 teapots. But if i use some high poly tree - i see only few of them. The less polys original object have the more trees appears on render. For example, 200 particles and 900k tree as instanced geometry - there are only 4 (or 5) trees on render, if I'll use PROoptimizer on original tree and reduce polycount to 5%, there are much more trees on render. Using other objects behave same way, more polys original geometry have - less objects on render.
Creating instances by copy/paste (not PF) seems to work fine. Tested on 2012/2013, 2.7.12/2.7.20
And not sure if that fixed already - 2013 does not save IES paths/filenames. After I open scene i need to select IES again. Seems like path is truncated. Checked on 2.7.12, 2012 and 2011 have no problems with that.
- Victor
- By Matteo Villa
