By ectonomics
#362945
This might be a stupid question but I having a problem texturing grass in C4D with maxwell plugin. the object plane is color/textured but grass is black.... MAC, Running C4D 13, MR 2.7.20 and plug in.... I know in studio you can add texture in primitive / material but not in C4D. I've followed the grass texturing link ( http://support.nextlimit.com/display/maxwelldocs/Grass ) using Example 1 - Using a texture in the UV 0 channel (root to tip) Example 2 - Using a texture in the UV 1 channel (grass surface) and Example 3 - Combining maps using both UV channels 0 and 1 using either 2 BSDFs or 2 Layers but all came up black. Do I need to add a tag or some thing?????
#362952
Oh, come on, it's easy enough to miss. If you're getting deep into some of that stuff, though, you might want to check out the 2.7.23 build linked in the top of this forum. That one supports rendering Cinema hair as Maxwell grass.
