- Fri Oct 26, 2012 1:08 pm
#361973
Here's a small piece of a larger model that renders fine in FIRE but makes Maxwell crash after a few seconds of computing.
I guess it has to do with the emitter being turned off (set to 0w)...?
This small model also triggers a question/request for setting a custom focal distance in isometric renders. When rendering this model (in FIRE), it turns out blurry.
In theory I should be able to sharpen the image by turning up the f-stop to an extreme value... Or I could turn off the isometric view and instead change my pespectives FOV to "1" (smallest angle) - and then use the Focal Distance-feature. But I would much rather be able to choose a focal point in the Iso-mode.
Btw. I still long for the option to set the f-stop-value to less than "1", OR to scale down the model at render-start, to obtain lower Depth of Field like in these photos
/Stefan
/Stefan
- By Edward Leibnitz
