- Fri Oct 26, 2012 3:57 am
#361961
Hi Guys,
I am trying to find an optimum work flow to do photomontages. Please find in the image below: a quick attempt to match the perspective of the building onto an existing site photo using Match Perspective Command in Sketch Up.
http://minorityexpress.wordpress.com/20 ... sketch-up/
In the image above, I have tried to match the points of existing roof and all context in the model is accurately modeled according to surveyor's drawings. So there is no error in terms of scale relative to design, etc.
The picture above is taken with an EOS SLR 350D, with a camera lens of 20mm. (Factoring in the Crop Factor of 1.6)
I have often found that the quickest way is to distort the design to fit onto the site or trying to manually adjust the photo to fit on site. See below.
http://minorityexpress.wordpress.com/20 ... -on-photo/
However, in tight deadlines and constant change in design, I find that I end up spending hours on image editing, etc. Is there a workflow which you guys have find more suitable in this instance? For example: Setting up a viewport which fits exactly to the image you produce which minimizes the work done on photoshop. I would love to hear from the ways which you guys contextualize your photos. Thanks!
- By Mark Bell
- By Edward Leibnitz
