- Thu Oct 11, 2012 7:01 am
#361514
when using maxwell with softimage, softimage is able to use the texture that was set for the viewport to display that texture in the hardware render for its viewport (not the final quality render, just the draft render),
which is cool, but if the maxwell material has only bump maps and otherwise just color settings, then the result in my softimage viewport is bound to what i could select in the "set texture displayed ..." as far as I so far figured out.
Question, which material parameter can I bind to another nice texture and set it to not have any effect on the final render ... so I could render myself the final color and import as dummy texture for the maxwell material ... to use in softimage and have a more pleasing environment while working ...
Regards,
Frank
Regards,
Frank
